Ok I have a strange issue with my ABS system and I've read most of the posts about the ABS Inop light and
seems to match.
If I go hard on the gas my ABS inop light comes on (Non-traction control). If I stop the car and turn it off then back on again the light goes out and stays out until I go hard on the gas again. I checked all the electrical connections to the sensors and back to where they terminate on the control valve, they all appear ok.
I tested the brakes to see if the ABS system was working and it seems to be ok, although I wasn't going very fast, maybe 20-25mph. I did slam on the brakes hard and they did not lock.
The only time the light comes on is when I go hard on the gas. Very weird, I'm hoping it's not a wheel bearing going bad, that seems to be the only thing that would explain it but the hubs seem tight. Or maybe an alignment issue could cause it? It's been a little while since I've had an alignment but it doesn't seem to be off and tires are wearing even.
seems to match.If I go hard on the gas my ABS inop light comes on (Non-traction control). If I stop the car and turn it off then back on again the light goes out and stays out until I go hard on the gas again. I checked all the electrical connections to the sensors and back to where they terminate on the control valve, they all appear ok.
