how much hp should i expect from some pulley's,Is it worth $265
how much hp to expect from pulleys
2000 red vw jetta,86k stock
Tags: None
both shops are tellin me Ill gain 15hp from some pulleys2000 blue mustang gt vert 5spd,18''cobra rims,light bar,stalker bodykit,lowered 2 1/2'',roush side exhaust /with x pipe ,bbk cai,power products 75mm tb and plenum Pro 5.0 3:90 gears,Custom 91 octane SCT tune
Stop listening to those shops. Those stupid shops are the ones that tell Ricers they get 100 hp from a wing and body kits. My brother bought one for his 96 Z and sold it 3 weeks later. Dont bother with that.Originally posted by DHolmesboth shops are tellin me Ill gain 15hp from some pulleysEddie
2000 M6 Trans Am
Tune+exhaust=344WHP
Im trying to find a mod i can do that will cost no more then $400,If I get headers it will cost me about $800 dollars with the install included,For 8 bills i dont know if its worth it2000 blue mustang gt vert 5spd,18''cobra rims,light bar,stalker bodykit,lowered 2 1/2'',roush side exhaust /with x pipe ,bbk cai,power products 75mm tb and plenum Pro 5.0 3:90 gears,Custom 91 octane SCT tune
I can buy afford chrome headers,these will still last for a long time and get as much hp as cermaic ??? i dont care if they change color2000 blue mustang gt vert 5spd,18''cobra rims,light bar,stalker bodykit,lowered 2 1/2'',roush side exhaust /with x pipe ,bbk cai,power products 75mm tb and plenum Pro 5.0 3:90 gears,Custom 91 octane SCT tune
Anyone who tells you that you will gain 15 HP with under-drive pullies on an LT1 doesn't have the slightest idea what they are talking about. Gains like that are remotely possible on an engine that has a belt driven water pump. But the LT1 does not have a belt driven water pump. Its gear driven off the back of the cam sprocket.
Here's a dyno test of an underdrive pulley on an LT1 engine. The gain was 0.7 HP peak.... less than 1 HP. There gain was a bit larger on average, but nowhere near 15HP.
http://www.ws6.com/mod-2.htm
You might want to look at the other dyno tests on that site:
http://www.ws6.com/mycar.htmFred
i have a 94 v6 camaro and i put the pulleys on it from summitracing.com for like 60 bucks and for only 60 bucks and that was only the crank i could tell a difference not worth 265 bucks but for 60 bucks or so from summit like i did i would suggest them just a couple bucks and a couple minutes of work youll know a diff.94 V6 A4~~LT1 M6~~383 M6 13.1 @ 109 with a 2.1 60' Sold/Stripped
94 Z28 383 A4 Sold
75 Chevy~~~~ SOLD
1992 Convertable RS 305/700r4 <<<Just a Beater
GOT PSi?
Good Cause Your Gonna Need It!!!
Again.... your V6 has a belt driven water pump, so slowing down the belt reduces the power consumed primarily by the water pump. The LT1 V8 does not have the same belt driven pump. It has a pump driven by a gear off the back of the cam sprocket on the timing set. It does not slow down when you put an underdrive pulley on it. It does not produce as much of a power gain as it does on your V6. Did you look at the dyno pull? Did you read what I posted?
The LT1 pulley is expensive, because it is integrated with the harmonic damper. I have never seen one that costs $265 - that's ridiculous. So I don't know where he got his price. You can get a "sandwich style" pulley that bolts behind the stock damper for less than $100. It will slow things down, but it adds mass to the rotating assembly. Not a good idea. An integrated underdrive pulley/damper from ASP will run less than $200, including an underdrive alternator pulley.
I bought the ASP set in 1995 when my car was less than 1 year old. It produced NO MEASURABLE OR SENSIBLE POWER GAINS. It was tested using a high-end accelerometer. No improvement in ET. But, it did produce a charging system that could not maintain full charge at the stock 800 RPM idle speed used on the M6 cars, at least not with the A/C and headlights or brake lights on. Its even worse on an A4 with the 550 PRM idle speed. Poor system voltage will hurt an EFI car's performance.
You will not feel the difference on an LT1.Fred
180 for the install and 85 for the pulley2000 blue mustang gt vert 5spd,18''cobra rims,light bar,stalker bodykit,lowered 2 1/2'',roush side exhaust /with x pipe ,bbk cai,power products 75mm tb and plenum Pro 5.0 3:90 gears,Custom 91 octane SCT tune
I wouldn't put one on my car if it was free.Originally posted by DHolmes180 for the install and 85 for the pulleyTracy
Why not save up your money to buy a mod that actually shows some proven results?
As Fred said, this site is a good start http://www.ws6.com/mycar.htm97 Trans Am A4 more or less stock (Mods: WS6 Ram Air with Fernco & K&N, 12 disc CD changer, power antenna, SLP Fan Switch, LS1 Aluminum DS, Borla Cat back, McCord power plate, Spohn tower brace, Sirius, HID fog lights)
You're willing to spend $400 on mods, but rather than going for something useful like gears or suspension pieces, you want something that people are telling you is useless and will give you charging problems...
I have a feeling you're going for the pulleys. Why is beyond me. For that money, you could probably swap to 4.10'sRed 95 Trans Am: M6, Moroso CAI, Magnaflow, Spohn sway bars, back to life as of 2/15/10!!!
SOLD- Kinda miss it
SOLD- Good riddance!
To pay someone $180 (3 hours of labor??) for a job that can take anywhere from 20-30 minutes is insane. Get under the car and save some money. That will let your $400 go a lot farther.Fred
