Hey guys, I got about 80k miles on my camaro now. I notice that around 1200 miles ago, my transmission has started to omit a sort of 'winding' noise when its in 1,2,3 at around >3k rpms. The clutch and flywheel as well as pressure plate were all replace around 5k miles ago, and were working great, so im fairly sure its in my transmission. The sound seems to go away or at least be less noticeable if i hold onto the shift level at those high rpms... However this may just be a misnomer. I've tightened the bolts on the shifter and made sure that the shifter cap is on tightly.
Has anyone had something similar to this? Or does anyone have any ideas what it could be?
Again, the noise is almost like the sound of gears that are not oiled properly rubbing when they contact. I checked the fluid level on my trans and it started to leak out a bit even before the plug was out all the way, so it seems filled to the brim. The fluid was also changed when i replaced my clutch 5000 or so miles ago.
Thanks in advance!
-Erik
Thanks in advance!
-Erik
