Hello all, I am new to the forum so I thought I would jump right in. I just hooked up an OBDII scanner to my computer and I was wondering if I have any chance of detonation by running the stock 14.7:1 ratio with my mods(97 formula WS6: LT4 hot cam kit, ported heads, long tubes). Also, I am getting a random misfire at idle. I just replaced the plugs and wires, so I know it's not that. Could it be simply because I haven't had the car tuned yet? I have to drive the car about 3 hours to get to someone with LT1 edit, so if there is any chance of detonation I guess I will have to trailer it down there. thanks...
Air to Fuel ratio
Air to Fuel ratio
1997 Formula WS6
43,000 miles, LT4 Hot Cam, 1.6 Roller Rockers, Ported Heads, Long Tubes, Borg Warner Built T56, Stage 3 Clutch, Aluminum Drive Shaft, Strange Engineering 12 bolt 4.11 Rearend, Nitrous Express wet shot.
2006 Saab 9-3 2.0T
18,000 miles, Stock, and staying that way (Daily Driver).Tags: None
fuel injector cleaner, i don't mean to sound like a ***** but check your plug wire locations and make sure all of them are plugged in tightly to the opti and to the plugs. one time, my steering column pulled out 2 of my plug wires when i was driving and boy did i feel like a chump. when i crawled under the car, the wires were gone, and i had to go find them on the street were i came from. Doh! another thing it could be, is what you were saying, the PCM doesn't know whats going on with the camshaft, and why there's so much more flow through the heads. i would suggest getting the PCM tuned. you can ship your entire module to a tuner and he'll tune it, and ship it back, for less than a ben franklin. hope this helps-Ryan-
I've heard a few horror stories about the "mail in" tuners. A lot of my buddies say that they have never had a computer come back right...they always had to send it back in to get it tweaked a little. Also, the only place I've heard of is pcmforless. I thought they charged about $175. There's a shop in North Carolina that has a pretty good track record. They charge $400 for a complete tune with three dyno runs...the last being a WOT tune. After that, all off dyno tuning is free for the rest of the time I own the car. Sounded like a pretty good deal to me. I'm interested in some other opinions on getting my computer tuned..1997 Formula WS6
2006 Saab 9-3 2.0T
Originally posted by 97formws6Hello all, I am new to the forum so I thought I would jump right in. I just hooked up an OBDII scanner to my computer and I was wondering if I have any chance of detonation by running the stock 14.7:1 ratio with my mods(97 formula WS6: LT4 hot cam kit, ported heads, long tubes). Also, I am getting a random misfire at idle. I just replaced the plugs and wires, so I know it's not that. Could it be simply because I haven't had the car tuned yet? I have to drive the car about 3 hours to get to someone with LT1 edit, so if there is any chance of detonation I guess I will have to trailer it down there. thanks...
There's not much you can do in the way of programming for closed loop operation. The 14.7:1 is hard-coded into the programming, and not something you can change with LT1_Edit or other programming software.
When you put the engine under load.... e.g. - wide open throttle..... the PCM is no longer operating at 14.7:1. It shifts to power enrichment (PE) mode operation, and sets a target A/F ratio based on various engine operating data. Typically, the resulting target A/F ratio in PE mode, with stock programming is 11.7:1. And that is "rich". You can pick up 12-15HP simply by leaning out the PE mode tables.
And again, if there is detonation, the knock sensor and knock retard system protects your engine from damage. You would have no risk in driving your car to a dyno for tuning. Your scanner should be able to show you how much knock retard the PCM is using.
With changes including the LT4 HOT cam and ported heads, a small misfire or a code for a misfire might not be all that unusal WITHOUT A TUNE. The PCM uses the crank position sensor to detect misfires. A cam without a tune may produce an irregular velocity pattern on the crank rotation that can show up as a misfire. In any case, you need a tune. Not tuning it can cause misfires.
I didn't see any injectors in your list of mods. Are you still running the stock 24 #/HR injectors?Fred
Yes, I'm still running the stock injectors. That was the next project, but I thought if I was going to do the injectors, I might as well do the intake...and if I was the intake, I had better put on a 58mm throttle body. I would love to do all of this work, but I don't have the cash. Would just getting bigger injectors give me pretty good improvements?1997 Formula WS6
2006 Saab 9-3 2.0T
i have the same misfire problem with mine is not consistent and only misses when im idling if you find the problem can you give me a shout so i can check and see if that is what is wrong with mine, plugs, wire, and all that is new ive tried all my basic knowledge and cant think of anything else94 V6 A4~~LT1 M6~~383 M6 13.1 @ 109 with a 2.1 60' Sold/Stripped
94 Z28 383 A4 Sold
75 Chevy~~~~ SOLD
GOT PSi?
Originally posted by 1slo_camaroi have the same misfire problem with mine is not consistent and only misses when im idling if you find the problem can you give me a shout so i can check and see if that is what is wrong with mine, plugs, wire, and all that is new ive tried all my basic knowledge and cant think of anything else1997 Formula WS6
2006 Saab 9-3 2.0T
OK..I think I'm going to go with bigger injectors. My only unknown is: If I put on bigger injectors, can I run the car without a tune with no damage?. I'm looking at the Accels on Summit. Probably the 36#. I know very little about injectors, so any input would be great. Like I said, my biggest concern is engine damage running the bigger injectors without a tune...as I have to drive the car a considerable amount for a tune. I've searched the forums for this info, but can't find it.1997 Formula WS6
2006 Saab 9-3 2.0T
as far as i know the computer will regulate the a/f ratio so it shouldnt mess it up its not like carburated where you have to set the a/f ratio yourself now a days we have damn computers to do it for us. so it should regulate the air (MAF) and the fuel pump to pump the right amount of fuel. MSD has coils and ive ran msd my whole life all from 4 cyl wrxs and geo trackers to 800hp BBC so i think highly of MSD ive had problems with accel. well good luck with your ride94 V6 A4~~LT1 M6~~383 M6 13.1 @ 109 with a 2.1 60' Sold/Stripped
94 Z28 383 A4 Sold
75 Chevy~~~~ SOLD
GOT PSi?
Originally posted by 97formws6OK..I think I'm going to go with bigger injectors. My only unknown is: If I put on bigger injectors, can I run the car without a tune with no damage?. I'm looking at the Accels on Summit. Probably the 36#. I know very little about injectors, so any input would be great. Like I said, my biggest concern is engine damage running the bigger injectors without a tune...as I have to drive the car a considerable amount for a tune. I've searched the forums for this info, but can't find it.
That was the next project, but I thought if I was going to do the injectors, I might as well do the intake...and if I was the intake, I had better put on a 58mm throttle body.Fred
Do NOT buy Accel injectors. In all the forums I cover, they appear to be nothing but problems. Everyone complains about them.
You keep your larger injectors in the boxes. You drive to the location where they are going to tune the car. While the tuner is loading the initial program into the PCM - including the new flow constant and offsets for the injectors - you swap out the injectors. There is no need to drive the car with large injectors on a stock program.Fred
Its showing misfires because you are running the stock tune. It is also probably extremely lean at WOT. I know when I put my HOT cam in my 96 WS6. That is what happened. It was even rocking on the dyno because it was so lean.
I ran the stock injectors in mine but didn't spray. That would be the only reason to upgrade injectors.
Get a tune and it will run a lot better. It will throw no codes and you'll be a lot happierRob
04 GTO
