My air conditioning hasnt been working. It doenst come out of the vents. It is like something is blocking it. But the weird thing is that it comes out from the bottom when i turn it on floor. Also, when i have it on max and as cold as it will go it will blow out hot air. I need to fix this! I cant drive my car during the day or i will have a heat stroke!
A/C Problems...HELP!
Check Shoebox's site. He has a photo of the HVAC vacuum connection on the manifold, the check valve, the reserve canister, etc. It all starts at the vacuumm connection on the passenger side of the intake, toward the rear.Fred
Ok i will check this when i get home. A couple of questions...if i find the leak, how do i fix it? And could this be hurting my performance any?1994 Pontiac Trans Am A4 Pacesetter Ceramic Coated Longtubes,3" ORY,Dual 3" Cutouts,No Cat,!AIR,!EGR,K&N CAI,Flowmaster Exhaust,Mad Z28 Tune,Spohn Subframe Connectors,Eibach Sportline Lowering Springs,KYB Shocks,17x9.5 Chrome ZO6 Rims,5% Tint
Chances are the Hose just slipped off or cracked. If possible you can just cut about 1/4" of the end and slip it right back on. As for it not blowing cold air at all, Check to see if the Compressor is activating at all. If it does not then the system might have to be recharged due to a leak in the A/C Recharge valves.
These are 2 different issues.Eddie
2000 M6 Trans Am
Tune+exhaust=344WHP
maybe not. If the diverter valves are not operating correctly, hot air enters the cabin.Originally posted by ConEliteChances are the Hose just slipped off or cracked. If possible you can just cut about 1/4" of the end and slip it right back on. As for it not blowing cold air at all, Check to see if the Compressor is activating at all. If it does not then the system might have to be recharged due to a leak in the A/C Recharge valves.
Well here's something else that is weird. During the winter, it wouldnt blow out heat out of the vents either, just the floor. And just about a month ago, it would blow out a little cold air through the floor. But now it is just HOT air. So nothing has been coming out of the vents since winter. I just didnt really care much about it to fix it. But now that there is no cold air at all, it is really a PITA to drive it during the day. I mean there isnt that much summer left, but i dont plan on selling the car so its something that i would need to fix.1994 Pontiac Trans Am A4 Pacesetter Ceramic Coated Longtubes,3" ORY,Dual 3" Cutouts,No Cat,!AIR,!EGR,K&N CAI,Flowmaster Exhaust,Mad Z28 Tune,Spohn Subframe Connectors,Eibach Sportline Lowering Springs,KYB Shocks,17x9.5 Chrome ZO6 Rims,5% Tint
Okay thanks. Well i will check out Shoebox' site, and try to fix it. But i'm no mechanic and only know basics. Would this be something i can check myself or should i take it into the shop?1994 Pontiac Trans Am A4 Pacesetter Ceramic Coated Longtubes,3" ORY,Dual 3" Cutouts,No Cat,!AIR,!EGR,K&N CAI,Flowmaster Exhaust,Mad Z28 Tune,Spohn Subframe Connectors,Eibach Sportline Lowering Springs,KYB Shocks,17x9.5 Chrome ZO6 Rims,5% Tint
