i have a 95 Z28. noticed that the nut on the rod was loose this morning.
got on it good several times this past week
. anyways i have 17x11 inch wheels with 315 tires. the tire on the passenger side is rubbing inside the fender. i can see the marks on the tire and on the inside of the fender.
the drivers side tire has
of the same issues. the rubbing is only under load and torque. i guess its not Centered correctly.
HOW do i center the rear using the adjustable panhard rod.
its a sphoon model rod.
any and all information very much appreciated..
ed
. anyways i have 17x11 inch wheels with 315 tires. the tire on the passenger side is rubbing inside the fender. i can see the marks on the tire and on the inside of the fender.the drivers side tire has
of the same issues. the rubbing is only under load and torque. i guess its not Centered correctly.HOW do i center the rear using the adjustable panhard rod.
ed
