When i left work earlier pulled out to go to stoplight i went to brake it stiffed up like ABS was on and the low trac light came on but it's not even wet outside my brakes felt weird yesterday. think time for brake change.
Brakes Having a Problem
Check the sensors for dirt and/or corrosion. I had a similar problem when the rear sensor on top of the differential housing came out of alignment. Mine was adjustable because its a Strange rear axle assembly, but a buildup of excessive metal particles on the sensor in a non-adjustable stock rear may cause the same problem.Fred
