streetability of 4.30 gears
  • streetability of 4.30 gears
    im ordering a 12 bolt tomorrow and am still undecided on gears. i only run 1/8 and dont do much out of town driving. would 4.30 gears be good. how would they run on the street.
    Adam 2kSS #4959 6-speed
    PERFORMANCE: whisper lid, mac headers w/ offroad y pipe, SLP Loudmouth, LS1 hotcam, ls6 springs, Predator, ngk tr6's, spec stage 3 x-pad, steel billet flywheel, 5177, purge, bottle heater, moser 12 bolt, 4.30 gears, tb coolant bypass, FRA, !cags, !egr, !A.I.R.
    SUSPENSION : eibach pro kit, bmr boxed lca & relocation brackets
    APPERENCE : clear corners, camaro fill in on front bumper and back, black and silver SS badges
    http://www.geocities.com/xxlo00oixx
    4:30's????????? hmmm.
    why not 4:10's..on an m6..they are very streetable.
    never heard of anyone getting "4:30's"
      the options on the 12 bolt go up to 4.56, there are also 4.30's, 4.11, 3.73, 3.42, and lower
        I have buddies here in KC with 4.10, 4.30s and 4.56s. Mike loves his 4.30s.
          4.30's are fairly streetable but one of the most important things is if your cam will work well with those gears. What cam are you running?
            ls1 hotcam, it has a power band about the same as stock.
              I know of the LT4 hotcam but I have never heard of the LS1 hotcam? What is the duration at .050, lift , and LSA? How big of a shot on your juice?
                You need to rev higher. Don't get that short of gears unless you increase the redline, you'll be rowing through the gears WAY too fast, and losing the torque multiplication in the lower gears too soon.
                  That is where I was going Jay, . Seriously though Jay is right Adam. With 4.30's and juice you would most likely have traction problems resulting in unpleasant 60 footers, and then when you did hook you would lose out on one the choice benefits of N2O, instantaneous torque. Try 3.90's, I think you would be happy.
                    218/227 525/525 112
                    100 shot
