Hey guys. I've been having an issue with the car for a while now, and it's gotten to the point where I just don't know what to do anymore. "A while" is defined as "at least two years" if you're wondering. I don't drive the car much, so I've related this issue to just a bug that would go away with some extended driving or perhaps something that would be fixed by general maintenance. At the end of September I took a long trip, and the entire time the car had this issue. Anything below 2 grand, any gear, light or heavy load, and the car hesitates. It's almost like a stutter the way it acts, but it's not throwing any codes. Above 2 grand, no problem, runs like a scalded dog.
Before I went on the trip, I changed the plugs and ran a can of BG 44K engine treatment in the car (awesome stuff, cleans valves, fuel injectors, all kinds of stuff.) The wires are in good shape, the fuel pressure is strong, no fuel leaks or anything like that. Keep in mind though that the car did this hesitation before any of that work was done, so it's not related to the engine treatment or the plugs, and those two things didn't fix the problem.
The car has 89k on it and it has never had an optispark or a water pump. I'm thinking that the opti is the problem, but the things I've read in the past (if I remember correctly) is the opti just goes out, not causes a problem like this, and certainly not for an extended period of time. The only thing the car has on the engine that is not factory is a set of Ford SVO 24# fuel injectors and an MSD 6AL (both items for the 5176 NOS dry kit that is on the car but currently not used). Other than that, it's an SLP loudmouth modified with two bullets instead of the SLP resonator, the cats are gone, a Global West Traclink torque arm, and Spohn poly ended adjustable LCA's and PHR.
Is there any way that the LT1 knock sensor could be picking up a false knock from all of the rearend modifications or perhaps the exhaust? The reason I ask that question is that all of that suspension stuff makes the rearend more solidly connected to the car, and I know the LT1 knock sensor is super sensitive anyway, so I don't know if it could be seeing all that chassis noise as a knock situation. If it is a knock sensor issue, do you replace the actual sensor or the chip in the ECM? If I do decide to use the nitrous again, is it safe to spray on a stock engine with the LT4 knock sensor with no tune?
