Hey guys,
To make a long story short, I had to replace my radiator in my 1996 Trans Am. When I finished, my SES light came on, which I discovered was because my coolant temp sensor was unplugged (which caused the car not to start at higher temps). I had to buy a new plug replacement and sensor because it had broken off. I soldered the new connector onto the wiring harness, and had no problems starting the car when it had warmed up, and the SES light had turned off.
Then I discovered, my car was STILL overheating. At idle, the temp slowly climbs up to the red line and then my coolant boils over (I have the cap off because I was trying to adjust the level because of the new radiator). I noticed that the fans are NOT turning on at all. I can't imagine it is something as simple as a fuse or wire because they were running fine before I had the whole problem and they were running with the SES light on. What could be the problem? The only thing I could think of is that the coolant temp sensor isnt working correctly, but the engine is running normally. Please help!
