Seems like I've gotten to the point where it's a new problem every three weeks or so with this car. Last week I had to replace the wiper motor control module. Not fun. I can't believe where they stuffed that motor into. So far I've been able to fix everything, but I'm really starting to get worn down....... I'm sure some of you have found yourselves in that position.
(I have a '94 formula, 6 speed by the way, street use only ....)
Anyway, last night I hit a "stealth" hole in an area of road construction, and immediately thereafter knew I had a rear suspension problem. On the way home the car made all sorts of thumping and banging noises from the right rear.
Got it up on the ramps today and was shocked at what I found!
Apparently, the spring perch on the passenger side busted nearly completely off! Most of it is gone. The coil spring is of course free at the bottom, and is cocked slightly to the side pointing inboard of the car. How it didn't come completely out and take out a bunch of other nearby components is a matter of **** luck I guess, if you can associate "luck" with this event at all.
I looked at the perch on the driver side, and although it is of course rusty, it looks otherwise o.k. These spring perches appear to be just welded onto the axle housing.....is that correct? Assuming this is true, this doesn't look like an easy fix. I can't imagine there is a replacement part for this, other than replacing the whole axle housing.
I know a complete aftermarket replacement rear-end will run me over a thousand, and be a project that I probably would not want to tackle on my own, and perhaps that would be overkill anyway. A used one from a salvage yard would be only about $400, but with the same sized project to face, (not to mention the task of trying to find one in good condition at this point......).
I've learned so much here from this board and the experts who regularly post here. Maybe one of you has a more cost effective suggestion than the ones I've mentioned above. I hope so. Although I am getting worn down on this car, I still in fact, love my old black bird, and would hate to have to take it out by the side of the road and "shoot" it.
Any suggestions would be most welcome. Thanks!
