Ive been on here a few times and all the help I recieved was great and I appreciate it. I have 1996 WS6 Trans am bought it over the summer. Havent driven it much due to one problem after another. So I am pretty sure the previous owners dogged it. So heres my dilema she is running great except for the oil leak. I put it on the lift yesterday to change plugs out the leak is steadily getting worse. The oil pan gasket looks good it seems to be leaking above the starter. Where could it be leaking from. It also doesnt look like its coming from rt valve cover. Thanks for any advice
So Here I am again
Sounds like the infamous LT1 Intake gasket leak. They leak in the back left hand side where the EGR tube goes down to the head. This is very common problem and the leak down onto the starter. You can let it cool and reach back there with your hand and see if it's real wet. There is some repair procedures out there, but Ken had the best right up on his site.
You can also check Rob's shoebox site for a lot of great info. I'll try to find the links and post them later..
Here's one..
http://shbox.com/1/4th_gen_tech1.html2005 GTO (mine) K&N CAI and Magnaflow exhaust, drilled and slotted rotors, and other minor mods.
2002 V6 Firebird (wifes)
2013 GMC Sierra (mine)
2011 Cadillac CTS4 (wifes)
there are a couple of notorious leaks.....
As was mentioned, the intake oil leak. the next is the dipstick tupe could be cracked or loose. The oil pan gasket can also leak... and right around the starter too. It is also theoretically possible for oil to leak from between the head and block, but that is really rare.
Here's a how-to on the intake leak repair. Don't spare the RTV or you'll end up doing it twice.
http://www.projecttransam.com/projects2.aspTracy, 97 Formula, pretty much stock.
