Just wondering how to replace my fuel filter I cant even get under the car lol
is it easy to replace a fuel filter in my 2000 firebird? If so how?
its really easy if you have a fuel disconnect tool if not you just have to push the line into the filter then push in the little buttons its a pain without the tool but can be done its how i did mine. the whole not getting under the car
haha that might be a problem.
94 V6 A4~~LT1 M6~~383 M6 13.1 @ 109 with a 2.1 60' Sold/Stripped
94 Z28 383 A4 Sold
75 Chevy~~~~ SOLD
GOT PSi?
It is probably close to how you do it on a 1995.Rob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
Amen, brother! It's a big ha-ha until you have one drop on you-Originally posted by BrdWAtti2dAnd then put it on stands....
Filter is easy, up in the frame rail in front of the driver's side rear tire- easy to follow the fuel line, and, yes, the tool to pop the connector makes it a lot easier- it can be done by hand, pushing the little 'ears' in, but it's fussy-
Technically, you are supposed to relieve the pressure on the line (there is a schrader valve under the hood, up on the fuel rails) but, if you haven't run the car in a couple hours, most likely the pressure has leaked down. Expect a few tablespoons of fuel to drip out- probably don't want to be smoking while you're doing this-
Most people don't change these any where near enough- it's cheap and can make a noticeable improvement in fuel delivery2001 Z28 A4 - 160 deg t-stat, 3.42 gears, WS6 sway bars, rear springs and shocks, UMI SFC's, Torque Arm and STB, leather Firebird seats, Borla, SLP Y-pipe and lid, ZO6 cam and springs - 332 RWHP and 346 RWTQ, not bad for 'almost stock' - work in progress
"Black, the fastest color"
yea "DONT SMOKE" HAHA if you cant get a jack underneath it summit racing has an airbag lift setup for our cars i dont think its really expensive but its soo you can lift the car up enough to get underneath it with a jack ill look for it online and get back to you i saw it in my book94 V6 A4~~LT1 M6~~383 M6 13.1 @ 109 with a 2.1 60' Sold/Stripped
94 Z28 383 A4 Sold
75 Chevy~~~~ SOLD
GOT PSi?
