hi, i have a 2002 ws6 t/a with about 33,000 miles on it and my alternator recently went out. i changed the alternator and have now had an issue with the voltage meter going nuts. it actually will some times go low enough to trip the check gauges light off then go back to normal. i have tried putting numerous alternators in thinking that possibly the voltage regulator was bad on the alternator (autozone pieces), but same problem. i checked the connection to the voltage regulator on the alternator and is fine. i was told to look into replacing the positive battery cables for possibly having a bad connection, did it and same problem. the problem occurs more so when it is hot out side. i can even be cruzing on the highway where the alternator is clearly being spun fast enough to charge properly and it will happen. the gauge will read fine then drop suddenly, go back to normal and fluctuate back and forth. i dont think that the gauge is bad. because when the meter drops the lights will actually dim also. i actually had a buddy hook a scan tool while car was running and problem occurring and was told that for some reason the car would read voltage and then not read it and so on.
any ideas will be greatly appreciated!!!
