I need torque specs on the heads and intake etc.
Torque specs LT1 head intake etc.
93 the manual uses torque figures but starting in 96 the method was changed to angle torque.
93-95 is 65 in-lbs
starting in 96:
Step 1: start with all bolts at 22 in-lbs
Step 2: short bolts turn an additional 67*º
Step 3: medium and long bolts turn an additional 80º
I found the rear head bolts under the cowl to be the most difficult to use an torque to angle gauge due to limited clearance and I reverted back to 65 in-lbs in 3 steps to make sure...... I've seen quite a few instances of the rear bolts being insuffeciently torqued causing head gasket leaks, particularly the #7 and #8 holes.
intake manifold bolts:
I use 71 in-lbs.
Joe, I hope you finish torquing the intake down...
71 lb. in. first pass
35 lb. ft. 2nd passRob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
Thanks i got the heads on and torqued. I got it almost back together but. As far as the valve adjustment is it 1 full turn on the rollers just like normal hyd. cams ?
I usually do them with #1 on comp and adjust half of them and then go to # 1 on overlap (#6 comp) and do the rest. 1 turn should put them at 0.100" preload.
Is that correct?
Stock preload is up to 1 turn. Less works, too. 1/2 to 3/4 or so.Rob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
Thanks Rob.
