will these rotors work on my car??
  • will these rotors work on my car??
    guyz will these work on my 94 v6??? i have front rotors and rear drum
    http://washingtondc.craigslist.org/n...551425412.html
    94 V6 A4~~LT1 M6~~383 M6 13.1 @ 109 with a 2.1 60' Sold/Stripped
    94 Z28 383 A4 Sold
    75 Chevy~~~~ SOLD
    GOT PSi?
    i wanna so no becuz i think the LT1 guys usually upgrade to the LS1 brakes cuz they are better/bigger
      ok i was just curious it was a good looking deal and i thought it would definatly help out also with my 94 v6 could a take a rear out of a 98-02 ss or z28 with disk in the back how much would it take to change it from drum to disk??
      94 Z28 383 A4 Sold
      75 Chevy~~~~ SOLD
      GOT PSi?
        You should be able to find a used rear that is complete with brakes for $300-350.
          swap meets and junkyards, any v8 car from 93-02 will fit
            Go here you may find it in your back yard http://www.car-part.com/
            Blazer
              alright thanks a million guys!!!
              94 Z28 383 A4 Sold
              75 Chevy~~~~ SOLD
              GOT PSi?
                Also get the driveshaft while you are at it. The V6s use a two piece, the V8s use a one piece.
                  ahh yes i forgot bout that part, if u can get a aluminum one
                    I thought the 98-02 cars had a 4 wire ABS setup and the 93-97 cars had a 3 wire? Wouldnt it make a big difference in order to work properly?
                    LarryMow-93 V6 Firebird-No engine mods-Z06 Wheels, '98 Taillights,'98 Center Console-SLP fan switch-BMR STB, F/R Swaybars, PHB,LCA,Torque Arm, SFC, Bilsteins, Eibachs....www.cardomain.com/ride/2489691/1
                      I could be wrong, but I think you are referring to 3 or 4 channel ABS. 3 channel is used when no traction control is installed, there is a single sensor on top of the differential. 4 channel is used with traction control and uses two sensors for the rear, one at each rear wheeel. Maybe someone else can chime in about the possibilty of differences in the wiring.......
                        u got it right joe, 4 channel is w/ traction, 3 channel is without, he prob has a 3 channel being a 6 banger and no posi,
