Hey guys,
I'm getting a code in my Trans Am after recently replacing a blown head gasket. I bought a scanner and am getting P0300, "random engine misfire". When you rev the engine, it seems to have a tiny shake and then all of a sudden smooths back out (same during driving; seems weak at lower RPMs and then all of a sudden picks up and the slight shake goes away). I checked all the plug wires on both the opti and the spark plugs, but everything seems to be tight. I haven't replaced the wires, but the spark plugs are brand new. The previous owner said he replaced the wires somewhat recently (although I don't know how true that is). I know that there are many things that could cause this problem, but does anyone have any suggestions on how to go about trouble shooting this? My scanner can record a limited amount of live data, but i'm trying to figure out how to narrow the misfire down. I've never used a scanner before so i'm not sure how everything works or what everything means yet. Any help with this would be greatly appreciated. Thank you!
It would be wise at that point to get taylor firesleeves to prtect the boots from the heat.
