Hi all. I have a '97 WS6 Trans-Am with 101k miles on it. The car is stock except for a K&N air filter. The stock spark plugs are due to be changed but I'd also like any opinions on other items to service. I've come up with this list:
Spark plugs
Inspect spark plug wires
Lube chassis components (suspensions components too?)
Check manual trans. fluid
Check rear limited slip diff. fluid
Inspect brakes
Here's what been done in the recent past:
5/24/04 Resurface flywheel, replace clutch, fuel filter
6/21/04 Replace rad hoses, coolant sensor, thermostat
8/27/04 Replace front disc pads, resurface front rotors, machine rear rotors, renew rear disc pads, replace battery, replace radiator
6/17/05 Clean fuel injectors/throttle
11/17/05 Replace coolant resevoir/hose
10/20/06 Replace EGR valve, replace serpentine belt
2/26/07 Replace water pump/thermostat, serpentine belt
I normally have the oil changed every 6k-8k miles with Mobil 1 (10w30). The oil was recently changed so that's not on the 100k list. The manual transmission and rear diff. fluids have never been changed. The last time I had a major servical interval work done was at 36k. Suprisingly there is not much in the owner's manual for 90k/100k different than any other interval except for the spark plugs.
Issues:
- fuel pump doesn't put out enough pressure. I only really notice this on cold starts, usually takes two turns of the key to get the car started. Warm starts it starts immediately. My shop says about $1000 for this repair so I'm not going to change the fuel pump unless there's a more serious problem.
- Shifting. Clutch has only 30k miles, but I've recently noticed that it's not shifting as smooth as before. Not all the time, but sometimes at the end of a shift movement I can feel/hear resistance. Not like the gears are being grinded, it's much more subtle.
- Only getting 22 mpg on the highway. Possibly due to stock plugs or fuel pump?
I've read on these forums that lots of folks prefer the MSD spark plug wires and NGK plugs. Since I've gotten 101k from the current plugs my plan is to replace them with the same type. I wouldn't mind using the MSD wires but since I'm not doing the work myself I don't know if the shop would install them for me since they are larger than stock.
Anything else? I love this car so I plan to keep it until it completely dies.
Thanks!
Spark plugs
Inspect brakes
Issues:
Thanks!
