Just went through my 3rd set of o2 sensors on my 1997 Camaro Z28 with a new LT1 after the last one through a rod : (. It seems the o2 sensors work fine for about 30 - 70 miles before they throw a code then they throw a code for not enough voltage from either side forget the exact code can't check while I'm at college, but I will check when i get home fro spring break in 2 weeks if i haven't fixed the problem. Anyway does anyone have any idea what could be causing the delayed set of the codes ? or the o2 sensors dieing ?
Also I still have a leak from the waterpump driveshaft seal which i will not be able to fix until spring break is there anyway this is causing the o2's a problem? maybe from coating the connectors from the extensions due to the headers in oil ?
