I installed 3.42 rear end gears so now I need to correct my speedometer. I bought a 45 tooth driven gear which is what I calculated for what I need to do the correction. I've seen a few different sites with this information but didn't really have a definitive answer. Do I need a different speed sensor to go with this 45 tooth gear? The 45 tooth gear is larger than the stock 37 so I have to assume there is some sort of problem with the meshing of the drive and driven gears. Any information will be greatly appreciated and as soon as possible. Thanks!!
Speedometer Gear Help!!?!?
