Hey guys,
I have had a problem with third gear jumping out for quite a while now on my car, but recently it has become much worse and I have had some other, more serious problems. The other day I was in fourth gear and went to put the car into neutral because I was at a stop light. When I tried, I could not even budge the shifter. I sat broken down for like 20 minutes, and finally it just released and was fine for the rest of the day. Today, I barely got the car into third gear once. It would kick it out immediately no matter what I did. On my way home, the car once again got stuck in fourth. After finally getting it out (I started driving it in fourth from a dead stop and it finally kicked it out), I drove home using only 1st, 2nd, and 5th. Sometimes when I put the car in neutral it would slightly grind fourth gear, and I have absolutely no idea why. Me and my friend are planning on dropping the transmission next weekend to bring it in for a rebuild somewhere, but I just wanted to see what you guys thought before I did anything thats going to cost a lot of money (haha).
I'm assuming my third gear (possibly fourth) gear syncro is bad, and I'm thinking the 3rd/4th shift fork is bent or damaged. What do you guys think?
Any suggestions would really be appreciated! Thank you!
