Attempted to take the Camaro out for it's first ride since last summer, but battery was dead. I jumped it while in my garage and it fired right up. Battery was very weak during winter start-ups but figured all it needed was a long drive to recharge.
Arrived at work with no problems during the drive. End of the day, the engine would crank but not fire...battery eventually died. Luckily I'm fairly close to an Auto parts store so I buy a new battery and install. Car would still not fire up, cranks fine but cannot hear the fuel pump. Return battery and have the car towed home. Recharged the old battery and still no luck. Neighbor has a GM Tech and P1626 was present so he cleared and motor fired right up only to die shortly thereafter.
Broke open the owner's manual and took out the spare key and again erased P1626. Motor started right up and ran for at least ten minutes. As before it eventually stalled and will now only crank.
SES is not on and the Security light goes off 5 seconds after the ignition is turned on. I can start the car by disconnecting the battery but it dies after 2 or 3 start-ups. I'm stumped at this point.
Should I purchase a new battery and have the P1626 cleared again?
I have also been experiencing an intermitten P100 MAF code which I'm not sure is related to the P1626. SES is currently not on.
Car is a 1997 Camaro LT4 SS with 20k miles.
Thanks in advance for any ideas or input.
