To those with the MSD 6-series....
  • To those with the MSD 6-series....
    Can anyone point me in the direction of an MSD 6A installation guide?
    I just want to see how involved it is and where i would put one.
    Thanks!
    -Ryan-
    If you pick up the plug and play harness, it's such a piece of cake. You simply hook up the +and - leads, unhook the connector at the coil and plug into the harness. The other harness end plugs back into the coil and you are good to go. I mounted my box next to the battery so that it's not near the majority of the engine heat.
      gracias once again JOe
      I picked up the 6A unit and the adapter harness. My brother and the manager at kragen hooked me up. They gave me the associate's discount AND a "missing part" discount! So i bought the MSD blaster coil with the difference
      -Ryan-
        What spark plugs should i be using with the 6A/Blaster Coil
        -non platinum: heat retention problems could lead to pre-ignition
        what gap?
        -Ryan-
          *bump
          -Ryan-
