So here it is guys the TA is running and its OK its not running as smooth as it should. When I am driving I get what I think is drive line vibration not sure what it is. It gets really bad after about 60 mph and stays thru, at first I thought it was the engine mounts so I changed them talk about a nightmare. I put a set of prothane on but it didnt fix it also I replaced the tranny damper as well. Any thoughts I am driving a 1996 ws6 tran am w/ no mods I am just trying to get it reliable everytime I get it going something else goes. Thanks again........
Bad Vibrations
Yep, I had the same problem and switched to an aluminum DS. Runs great now.Originally posted by Joe 1320driveshaft. There was a TSB about the issue, the steel driveshafts from the factory were usually out of balence, the fix was to have the dealer replace the driveshaft with the aluminum 1LE shaft.
I bought my LS1 DS used from Ebay.97 Trans Am A4 more or less stock (Mods: WS6 Ram Air with Fernco & K&N, 12 disc CD changer, power antenna, SLP Fan Switch, LS1 Aluminum DS, Borla Cat back, McCord power plate, Spohn tower brace, Sirius, HID fog lights)
Sorry, but GM hasn't honored the TSB in 10 years.Al 96 Ram Air T/A
