My air conditioning used to work a little bit and the compressor finally shut off after the ref. finally leaked out and their was no pressure for it to engage. I haven't used it for a year and finally decided to fix it. I went out and bought a refill kit with a gauge and all, I then jumped the relay (b1-B4) and had the compressor running and pumped some ref. into the system. The reading went from like 5 psi to 100 after a few seconds and it still feels like their is alot in the can.
The compressor now engages without having to jump it, so I suppose it has a sufficient amount in it?
I also think I found my leak, after I shut the car off I heard hissing from this area. You could feel air at the top of the condenser coming out and the psi started dropping.
The condenser is all rusty on each corner, if this is leaking could this be my only problem, how do i let the pressure out to remove my condenser. Should i refill my dryer? Also, i found some condensers on ebay from salvage yards out of newer camaros and birds, will these work?
Thanks for looking!
Thanks for looking!
