BCM Diagnotic Trouble Codes
  • BCM Diagnotic Trouble Codes
    Well, I finally got a chance to check the BCM in my 2000 Camaro and found the following codes:
    DTC 25 - Security Indicator Status
    History Codes
    DTC 31 - Courtesy Lamps Feed Shorted to Ground
    DTC 33 - RAP Feed Shorted to Ground or Battery
    DTC 35 - Secuirty Indicator Status
    I know what the codes are, but what are the steps to testing or correcting them? Anyone out there have any ideas? The only odd thing going on is the radio turns off for about 3 seconds and comes back on while driving. Also, the RAP will sometimes not work once the key is turned to off position and the doors have not been opened. Thanks for your help.
    1988 5.0 TBI Camaro 700R4 Transmission
    2000 3.8 SFI Camaro 4L60E Transmission, K&N Air Filter, and Drill/Slotted Rotors all around.
