like it says im looking at a 3.42 geared rear with drums im not sure the mileage but prolly 70-80 i believe. how much would you all say it would be worth?
A Decent Rear 3.42 Drum??? WORTH???
just cause the one i have now is a drum setup and i really dont have time with winter approaching quick to have to much more down time with my car it will just a much easier swap with the E-Brake. or so i was told.94 V6 A4~~LT1 M6~~383 M6 13.1 @ 109 with a 2.1 60' Sold/Stripped
94 Z28 383 A4 Sold
75 Chevy~~~~ SOLD
1992 Convertable RS 305/700r4 <<<Just a Beater
GOT PSi?
Good Cause Your Gonna Need It!!!
The rears with the drum brakes are from the V6, and typically do not have a posi differential.Fred
So how much work would it take to switch over to the disc rear. cause i have the old rear housing i just need everything else cause i wire brushed it and everything and painted and got it real clean. but just curious what all i would have to do to change it94 V6 A4~~LT1 M6~~383 M6 13.1 @ 109 with a 2.1 60' Sold/Stripped
94 Z28 383 A4 Sold
75 Chevy~~~~ SOLD
GOT PSi?
go to a junkyard, i got mine with 39K on it for 125$ that was for a third gen 3.42 drum rear tho. i beleive all u need to make the disc brake one work is the cables, make sure to get the LS1 style rear tho. much better set-up2009 Honda Civic EX- the daily beater
well i mean i have the 94 z rear with all the brackets and everything but hte center carrier. we pulled it and now the thing is gone. so what would everyone suggest from here? just buy a new center carrier and all the guts or just junk it and go find a LS1 rear94 V6 A4~~LT1 M6~~383 M6 13.1 @ 109 with a 2.1 60' Sold/Stripped
94 Z28 383 A4 Sold
75 Chevy~~~~ SOLD
GOT PSi?
LS1 rears are gonna be a few bucks more then a LT1 rear. try www.thirdgen.org, its a popular swap onto us third genners cars so u prob have more luck finding a rear there for a decent price2009 Honda Civic EX- the daily beater
In terms of strength, the LS1 rear axle assembly is no different that the LT1. Mechanically, they are the same unit. I believe the posi unit is a bit different in the later ones, but they are no better than an LT1 rear.
When you say the "center section" is missing, what is gone.... the carrier and the ring gear? You will have to buy a new carrier, new ring and pinion, an intall kit, etc. Add the gear install, and you are probably looking at about $1,000. You would be better off finding an intact assembly from V8, preferably an M6, if you want the 3.42's. If you are saying the one you have has 3.42's, it doesn't appear to have a complete set of gears. Sounds basically useless.Fred
