I'm still fighting the issue of split BLMs. Everything still points to an exhaust leak at the collector, which I've been trying to fix for a long time. All that I've been doing is making it worse. Now I'm seeing a constant 5 degrees of KR at idle. I've tried Felpro 60986 2.5 donut gaskets, but the leak is now worse. I even tried using lots of copper RTV to seal, but that didn't help at all. I think I'm going to try SLPs original collector gaskets again. Otherwise, I don't know what else to do, to fix the leak.
One other thing I noticed was that a scan after shut-down (car not running but key on) showed that the driver's side O2 was fluctuating between .142 and .147 volts. The passenger's side was a constant 0.089. Does this mean that there's something going on with one of the O2s?
