Slp Roll control install instructions
  • Slp Roll control install instructions
    Hi all,
    I just bought a used SLP line lock kit for my 93 camaro. However i don't have any instructions. I went to SLP's site but had no luck finding any. Just need to know where i need to tie the lines in. I'm assuming i will need to put some teflon tape on the threads also to avoid leaks. Thanks in advance for any help.
    Lew
    Well All you have to do is tap into the front brake line from the master cylinder over to the Block (That block that I believe controls the ABS or something).
    I dont recall how exactly the '93's are but its pretty much the same idea. Did you get the pre-bent lines as well?
    Also be careful when you loosen the OG lines. They sometimes strip and then you will seriously have a ball loosening them up.
    Eddie
    2000 M6 Trans Am
    Tune+exhaust=344WHP
      Thanks and yes i have the prebent lines.
        Sounds good. Yeah just make sure to use a relay and hook eveyrthing up using proper conections and not mickey mouse anything. Saves you from drama down the road.
        Eddie
        2000 M6 Trans Am
        Tune+exhaust=344WHP
          get flare nut wrenchs otherwise u will strip the nuts and no need for tape on the threads, should be at least a double flare on the end of the line
            Will do thanks again. Do i have to drain the whole system or can i get away with adding the new lines followed by bleeding?
              considering that you probably don't know how old that fuid actually is, if it were me there would be a complete fluid change.
                I believe they call them Fuel Line wrenches. Even with those considering the age, you might have to take some vice grips to them. We had to on my brother '96 Z. Joe has a good point. Just go ahead and change the lines and follow that with a good Bleed to every corner of the car. This way you have all new fluid through the lines. When I got my car 2 years ago, I went to bleed the air out of the front after the line-lock install and the fluid was Green. It was nasty so I went through about 4 res. full of break fluid and man what a difference it make in the pedal feel.
                Eddie
                2000 M6 Trans Am
                Tune+exhaust=344WHP
                  http://buy1.snapon.com/catalog/item....re&dir=catalog
                  flare nut wrenches, they arent jsut used on fuel lines, as we all know
                    Hmm, thats what we used to call them back in the days. ha ha ha
                    but yeah those.
                    Eddie
                    2000 M6 Trans Am
                    Tune+exhaust=344WHP
                      Thanks everyone. Joe guess that was kind of a dumb question considering i haven't changed the fuild and who knows when or if it was ever changed. I'm sure it has as old as the car is.I had fluid break down on my motorcycle once and being in a sealed system it was amazing how dirty the fluid gets after time.
