Normal Cat. Temp.?
  • Normal Cat. Temp.?
    What is the normal Exterior Temp. of the cats on my car. Does anyone know? Fred?
    Eddie
    2000 M6 Trans Am
    Tune+exhaust=344WHP
    Don't know. The internals have to be over 600*F before the catalyst starts to work. The internals are usually isolated from the shell by a compressed wire mesh (at least that's the way they were many years ago when I worked on designing a plant fo manufacture them). But they get hot enough to start fires if you park over leaves or dead grass.... that's why they have the heat shields.
      Somewhere between "hot" and "freaking hot"- Every OEM set-up I have ever seen included a heat shield between the cat and the floorpan of the vehicle- I am trying to recall if I have ever seen cats glowing red-hot. I KNOW I have seen exhaust manifolds do it-
      "Black, the fastest color"
        Using paper as a substitute for leaves, we can assume that since the autoignition point (of paper) is 842 degrees F, than the exterior of the cat has to be above that point. Also, normal cat. internal temp, as Fred stated is above 600 degrees, and I believe I read somewhere that the cats can operate safely as high as 2200 degrees F, one can assume the exterior is somewhere between 800 and 1500 degrees.
        I would not expect the exterior to get any hotter since they are air-cooled (driving allows air to pass over them), and the cases are usually insulated from the interior catalyst bed.
        Al 96 Ram Air T/A
          When your cats start to get red hot thats a perfect sign that they are clogged. They should never get red hot. Inside the cat is a different story. On my old honda The Manifold would get a very light light red in a very dark area after a long drive, but not the cat.
          Eddie
          2000 M6 Trans Am
          Tune+exhaust=344WHP
            I'm going to go with "Ow that f-ing hurt" °
            My DD
            2015 Lexus GS350 FSport
            My toy
