I have a 97 T/A with LT1 and my water pump killed optispark. My problem is I can't get the 3 bolts out of the balancer. I know this probably sounds stupid but Just hoping somebody has a nice trick. The WD40 just not working for me.
Need little help with optispark install
Yep...what he said. WD40 is designed to displace water, hence the name Water Displacement (WD40).
Make sure you put a socket on the hub bolt to restrict the pulley from turning. Otherwise, as soon as you get enough force to break the bolts loose, the crank will want to spin.Al 96 Ram Air T/A
