I've been searching for a couple of days now, and can't seem to get a simple answer.
I'm thinking the rear u-joint (pinion side) is starting to show some wear, so rather than just replace one, I''m most likely going to replace both. I've searched for the proper u-joint p/n, but can't find any definitive answers.
I know the 1LE requires a different u-joint than the steel DS. However, the answers I found, "the rear one needs a combo unit," "the front one is standard", "just get the one GM also uses" are about as vague as can be.
Does anyone have a p/n for the u-joint on the tranny side and a p/n for the u-joint on the pinion yoke side (using the 1LE DS)? This is driving me nuts...
Also, are u-joint girdles necessary, or just fluff? I noticed on Summit that several manufacturers make girdles/straps, but can't tell if they're overkill for my power (350 hp, 375 ft/lbs). I'm just looking for a reliable set-up.
Oh yeah...I've had a driveline (I think...not sure if it's a tire yet) vibe at 70+ and want to eliminate the source. I found one tire out of balance, so I rebalanced but haven't tested it out at speed yet. I noticed the u-joint had some resistance and was popping when I had it off, so I want to remedy over the winter.
