I have a Set of Stock 17's SS/ZR1 wheels from a local guy. Im not sure if they are 8.5" or 9.5" Wide. My guess is they are 9.5". Can I run a 285/40ZR17 on these wheels with no issues or should I leave them on 275's.
Max Tire width on SS wheel? Fred?
I believe the SS wheel is 17" X 9" while the ZR1 is 17" X 9.5".
For the SS wheel no and for the ZR1 wheel yes.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Originally posted by Jeff_in_AtlI believe the SS wheel is 17" X 9" while the ZR1 is 17" X 9.5".
For the SS wheel no and for the ZR1 wheel yes.Eddie
2000 M6 Trans Am
Tune+exhaust=344WHP
Sounds like either way will be OK.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Originally posted by ConEliteWell they are ZR1 style rims. The guy I bought them from Said they came on his Camaro SS. They are the 5-spoke ones so you think they are 9.5"
SS Camaro wheels look just like ZR-1 wheels but in fact, are not. a 17x9 inch wheel will measure 9.5 inches wide as each lip adds a 1/4" to the total measurement. So..... a 9" wide wheel will measure 9.5", and a 9.5" wheel will measure 10". SS Camaro wheels are 17x9 on all four corners, Corvette wheels came in 17x9.5 on the front, 17x11 on the rear.
Thanks guysEddie
2000 M6 Trans Am
Tune+exhaust=344WHP
Choose your tires carefully. A 285 is only 4/10th's of an inch wider than the 275 at the widest point on the sidewall. The diameter is less 1/3" larger. Its not going to look much different or perform much different. What diameter is your speedometer calibrated for?
If you look at the specifications for a variety of tires, you will find that there are 275's that have a wider tread and more aggressive look than some other 285's. Tread width does not correlate to traction or performance - some of the highest rated tires for wet and dry traction have narrower tread than the lower rated ones. I'd focus more on the tire characteristics that you feel are important -dry traction, wet traction, cornering, tread wear, noise, harshness, etc. If its all about appearance, its something else.Fred
I want some good Dry tires. It never really rains around here so thats not to important. I want these to be able to Carve canyons. Something with a good Traction rating.
Im leaning to the Kumhos. Im going to go with 275's.
My car is calabrated for stock 16's. Im guessing 245-45-R16. Will that make my speedo be off by a lot?Eddie
2000 M6 Trans Am
Tune+exhaust=344WHP
I would run Nittos if you want sticky without crazy prices.
I ran 555s for many years, but if you want sticky, I would go 555RIIs.
Here are some specs...I too upgraded from 16's to 17's (Nittos)
Size----Dia------Width---Approved Rim Sizes--Revs/Mile
245---25.59"----9.61"----7.0-[7.5]-8.0----------811 <---450s (275 not avali)
275---25.59"---11.02"----9.0-[9.5]-10-----------813 <---555s
285---25.62"---11.38"----9.0-[10]-11-----------800 <---555s
As you can see, the dia are so close there shouldn't be any adverse effects that you'd have to tune. Just swap and enjoy.
Again, check out Nittos. 555s, NT03 or the NT05 <---sick tire
www.nittotire.com
Originally posted by ChristopherrrI would run Nittos if you want sticky without crazy prices.
As you can see, the dia are so close there shouldn't be any adverse effects that you'd have to tune. Just swap and enjoy.Eddie
2000 M6 Trans Am
Tune+exhaust=344WHP
Originally posted by FroSStyI wouldn't buy the kumhos if I had to do it again...The sidewalls started weather cracking after about 10k miles and the tread didn't last long. At first the wet traction was good(compared to the old worn out bfgs) but after a little wear, the tended to spin in the wet more often. .02
Im going to start calling around here in my area for the Nitto 555's. They are about $160 a piece from Summit so If I can get them around my area for less than $180 installed a piece it looks like im getting new tires tomorrow.Eddie
2000 M6 Trans Am
Tune+exhaust=344WHP
555's were awesome tires! I have Falken 452's right now and they are okay in comparison.
The 555's lasted 48K miles...Discount Tire rotated and balanced them every 6K. Even at 48K, it was only at the wear indicators and I could have kept going.
Strong grip and handling...
Yeah I have those badboys installed. Got only 2 tires since two were pretty much new. I must say, even though they are not broken in yet, they are much better than the hunks of junk I had before.
I paid $330 for two Nitto 555's, installed, all 4 wheels balanced, and new lug nuts.Eddie
2000 M6 Trans Am
Tune+exhaust=344WHP
