I installed the brass gear in my headlight motor assembly about 6 months ago and I'm having a heck of a time keeping the thing together. I've tried 3 different epoxies 2 x each for a total of 6 times and after working for a little while it lets loose. It always fails in the up position when the headlight door linkage is under a heavy load. Besides the epo-tek epoxy that comes with it, I used industrial epoxies designed to adhere with plastic. I also cleaned the surfaces with methanol and acetone prior to applying the epoxy. I gave up and went out and bought a new assembly. I ususally don't go down in defeat like this but I'm at wits end with the stupid thing.
What have you all down that makes this work?
Thanks,
Warren
Thanks,
Warren
