2 days ago I went to pass someone on the highway and when I got about even with the car I was passing I heard a really loud POP from the exhaust, I was going about 80mph-4000rpm. Then the check engine light came on and it ran rough for about 1 minute then seemed to clear up, check engine light was still on though. I got to work and shut it down. After I got off work I fired it up and it ran fine for about 15 minutes, no check engine light (I drive about 130 miles a day round trip.) While cruising down the highway at 65 mph-1650rpm it popped again. This time twice but alot quieter. Then the check engine light came on and it ran rough for about a minute and then cleared out again. I drove it real easy for about 30 miles and pulled over at a gas station. I popped the hood and noticed both of the radiator fans were on which is weird since it was like 17 degrees outside and the temp gauge was only about 1/4 of the way up, maybe 160-170 degrees. When I took off from the gas station it lugged down real bad, ex. 600rpm idle-push the gas-300rpm, then right back up to 600rpm and accelerated smoothly. I got home and shut it off then fired it right back up, no check engine light, the radiator fans weren't on and no lug off of idle. I drove it around today and it ran great
. It is a 94 T/A, auto, 176,XXXmiles, completely stock except for the cat being remove a long time before I got it. Thanks in advance for anybody's help on this matter.
