Bulb or the flasher
  • Bulb or the flasher
    My passenger side marker light is burnt out. How to get to it? I tried from the top and cant get my hand down. I can reach the 194 tiny marker bulb and wire. But cant reach or find the 3157 bulb/drl. So right now when i use my left turn signal it stays lit on the gauge and the tail light stays lit. Burnt bulb right?
    2000 Z28 SLP sub frames, J&M LCA's, KYB shocks, Waitforme tuning. Ported TB & intake 35/22 swaybars, Firehawk tires
    aha On mine i opened the headlight to get my arm under, but you obviously don't have that option. thry going from underneath, jack it up, remover the splash panel and it should be an 18 inch reach into the front faring. the buld will come ouf of the top of the assembly(turn signal) and the side(small marker bulb).
    -Alex
    ZO6 wheels (clones)
    With questionable guts:
    Forged bottom end
    pacesetter longtubes
    K&N RAM air from 96 ws6
    96? ws6 hood
    96? ws6 spoiler
    full emissions delete
    Edelbrock IAS shocks
      ugggh , guess I gota drag out the rhino ramps
