After my last post on 1/9 5:03 pm,I decided to go to grocery store 4 miles away.1/2 way there it died.After about 15-20 seconds it restarted drove about 500 feet died again.While coasting restarted in about 15-20 seconds.Made it to the turn light at the store,died again.Restarted 15-20 seconds.Rushed into parking lot died again no restart.Coasted in the lot till I found a well lit space.Opened the hood and called my neighbor for a ride.While I was
on him let it cool off for 30 minutes till he got there.Restarted, high tailed
it home.Shut it off. Got out kicked the tires went inside.Next day at daylight went out side..This is what happened.[1] Started right up,ran for 30 minutes during which time the following happened.Fan switch on,hood up.During the 30 minutes idle was 650. I stepped on the gas and took it to 1500-2000 rpm many times. 30 minutes in, the idle increased to 1000 rpm and there was a slight dip on the dash volt meter. stepped on the gas died, no start. [2] after 40 minute cool down restarted with hesitation.Closed hood.After about 1 1/2 to 2 minutes code 15.Idled at 650 and I took it to 1500-2000 rpm. After 8 minutes the idle increased to 1000 rpm with same dip on volt meter,stepped on gas died, no restart.[3]After 45 minute cool down restated with hesitation. Closed hood, fan switch on,idled at 650.After 3 1/2 minutes,Idle increased to 1000 rpm. Stepped on gas died again. [4] After 65 minute cool down restarted again with hesitation.Fans switch on,hood closed. About 30-45 seconds code #15 on then off.Code #15 back on after 5 minutes and off at 6 1/2 minutes. At 8 1/4 minutes idle went to 1000rpm.Stepped on gas died. No restart..[5] 60 minute cool down.Restarted hard. Idle 650rpm.After 1 minute code#15on After 5 minutes same as above died, Restarted hard 650 rpm then it went to 1000.Didn't step on gas. After about 15 seconds idled back to 650.This went on for 3 minutes..Idle to 1000 rpm and back to 650 rpm about every minute. At 12 minutes in, idle to 1000 rpm, stepped on gas,died. No restart..Since it was getting dark I got out re-kicked tires said a few cuss words and called it a night.
During one of the above I checked a plug,no spark.Checked coil wire going to Opti no spark.Today I measured ohms of the temp.sensor at the temp.according to shoe box. First is temp,second is shoe box ohms,third is my ohms. go.-----212-177-172,194-241-212,176-332-290,158-467-425,140-667-600,
122-973-915,113-1188-1160,104-1459-1410,95-1802-1685,86-2238-2170,
77-2796-2720,68-3520-3310....Really hope someone can help correct this problem with the above info. Back to work tomorrow,maybe..
