So after about 60 miles on the new motor, it started sputtering at around 3k+ rpm, and then suddenly died on me. I tried to restart the engine but nothing. It didnt even try to start. It turns over fine, but absolutely no thunder. I checked the fuel pressure and saw 43 psi at the valve. I pulled the two front spark plugs on the driver side and put them againts the header bolt to ground them and they both had spark but was very dim, and looked weak considering it was dark.
The car didnt throw any codes, and the only thing I did different this time I drove it was to take out the ABS Fuses and replace the O2 sensors. The ICM has 11.53 volts on one side and -11.53 volts on the other side of the connector. I reused my old Optispark (10k Miles, OEM), and MSD Coil. The ICM is probably the original one from 96. Before this, the car would start and idle fine when cold, but would either idle poorly or turn off after it warmed up and was restarted. I have the MSD 8.5mm Wires that are 8 years old and have about 40K miles. Car currently has 117K miles. If it was the Opti, or connector, would it still spark? Im lost
Any ideas?
Any ideas?
I replaced both the IC module and Coil, and checked for spark on 2 other cylinders. Both had a bright spark, but still no thunder. I checked compression on 2 cylinders, and had 160 psi on both. I take it its time for an OPTI?
lol
I have never heard this from Injuneer. You better doublecheck that.
I had never heard of the Dynaspark, but based on their website and Zs testimonial, it looks like the best bet.
