02 sensors
  • 02 sensors
    Are the three O2 sensors the same on the 5.7 l engine? Ay Oreillys they said there are only two, but I know there are three one after each exhaust manifold and one after the cAt. Are all three identical?
    I will be installing new Magnaflow direct fit repalcement cats tomorrow, and have decided to just replace all three 02 sensors, but don't want to screw it up. Thanks.
    2000 Z-28 Convertible, neutral leather interior and neutral top, hotchkis STB, SLP Bowtie Grill, WhisperLid, K&N, cold air induction
    No, they are not identical. The pre-cat sensors are the same.
      Also, unless I'm just not reading you correctly, you have 4 sensors, not three. You said it yourself: one after each manifold, and one after EACH Cat. You have two cats., not one, so you have 4 sensors.
      And like Shoebox said, there are two types of sensors: square connectors and flat connectors (pre cat and post cat).
      Al 96 Ram Air T/A
        all installed, and working great no SES lights after 175 miles! biggest problem was 4 broken manifold studs outof six, but GM dealer came through with the studs!!
        Biggest headache was that Magnaflow did not include teh gaskets between the manifold and the Cat pipes-two of teh strangest looking gaskets I have ever seen. Had to break to get the gaskets, but again GM came through.
        and this was the fiorst major repair I have had beside repalcing teh pinion gear about 60,000 miles ago. Still on the original clutch, and the original brake rotors--guess teh'll go at some point too.
        But beyond that, ready for another 136,000 miles!!!!!
