The low oil light keeps coming on. My oil level is fine. anyone have a clue as to what is causing this??
Low Oil Light
Low Oil Light
96 Black A4 T-Top TransAm
ARP Main Studs...ARP Head Bolts...Edelbrock Heads...CC306...Manley One Piece Pushrods...Stainless 1.6 Roller Rockers...Comp Guideplates...3000 Stall...MSD 6AL...BBK Shorties...Magnaflow Catback...Performabuilt Level 2 4L60E...NOS 150 Shot...98' Up Front End Conversion...Granatelli Air Lid(LS1 Style Intake)...MadTuner.com Tune
Run Your Car...Not Your Mouth!Tags: None
There is a sensor in the side of the oil pan that detects the level in the pan.
As usual, Shoebox has the info... http://shbox.com/1/low_oil_sensor.jpg
Either the sensor has gone bad or the wiring to the sensor is bad. Mine was both unfortunately but I managed to repair the wiring and the sensor was inexpensive.
Try here:
http://www.oreillyauto.com/EW3/Displ...ycleCount=2553My DD
2015 Lexus GS350 FSport
My toy
ah! gotcha.
yea, it comes on and off all the time. Im going to have to check um out. hopefully its not the sensor or i'll have to wait till the next time i change my oil to change it out.
thanks man.
I noticed you have headers. Make sure the wire going to the sensor hasn't fallen onto the header and burned through the insulation. I believe if the wire touches ground it will make the light come on.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
