Trans Question
  • Trans Question
    Hey I was just wondering if anyone else may have experienced this or have any idea what is going on-- MY 96 Z28 A4 sat for several months and after getting it going it is shifting odd. It does not want to go into the next gear, it is not slipping or anything it just does not even try it just keeps reving up. Once it is about 2000rpm(usually sometimes it is higher) I can lift up off the gas and then press it again and it will shift into the next gear and it does this in every gear. I am not sure if it is something in the computer or mechanical. I did have some engine work done while it was sitting.
    Thanks for any info or ideas
    Black '96 Z28, loudmouth exhaust, Mac mid length headers, crane cams powermax 104227 cam, crane 1.6rr,'s, springs, lifters and pushrods. MSD distributor, slp ultra z hood with air box, bbk 52mm throttle body, march underdrive pulleys, hpp+, 1le sway bars, spohn LCA's and relo brackets, Spohn SFC's, adj panhard bar, bilstein shocks, H&R springs, strut tower brace...Audio-Alpine head unit, MB Quart 6.5" component in the front and 6.5" Boston in the rear w Alpine 75x4 amp, Alpine Type-X 12 in the trunk w/ alpine 1000w amp
    Why not try a Trans Service. When Was the last time it was done? Even better, a trans flush!
    Eddie
    2000 M6 Trans Am
    Tune+exhaust=344WHP
      I agree that is where I would start first. Then take it to a reputable trans shop for an inspection/test. Good Luck
      www.lackomotorsports.com
      2001 Dodge Cummins
      1997 Z28 SS 30th Drag Car
      1996 Z28 Drag Car
      1993 Z28 Drag Car
      1985 Monte SS 48,000 original miles
      2003 Trailblazer (wifes vehicle)
        What kind of engine work did you have done?
        If you decide to get the trans service as previously suggested. And your car has alot of miles on it and/or the trans hasnt been serviced in a while make sure you tell the mechanic that you dont want him to use any detergent when he is flushing the trans. This will cause it to start slipping.
        No F-Body right now
          Last time I saw my past co worker Flush a trans, They flushed the old fluid with NEW fluid.
          Eddie
          2000 M6 Trans Am
          Tune+exhaust=344WHP
