I had another disappointing day at the dyno, only putting down 340 RWHP. The good thing is that it put down 340 from 5500 all the way to 6600 RPM, so it was a huge "under the curve" area.
Here's the weird thing: the car wasn't that responsive to changes in the AFR when the tuner would load a new flash of LT1edit. On the first pull, it was running extremely rich at 10.0:1 AFR. He shut it down at 6k and it put down 324 RWHP. The next pull was 12.2:1 AFR and ran it to about 6600 and it put down 339 RWHP. The last pull was 12.4:1 and it gained 1 RWHP to 340. I've heard of stock LT1 AFR changes from 11.7 to 12.7 and gaining 15 RWHP. I don't understand why my setup only gained that amount going from 10.0:1 to 12.4:1. The heads flow 288 CFM @ .600 so I would have thought AFR is crucial to the #s. Does this change in AFR to hp sound right?
Also, I am at a loss trying to figure out why my previous tune went sour at 10.0:1 AFR. It was set to 12.4 previously, so I don't know what went wrong. I did clean up the filter and change the plugs (engine builder put in nitrous TR-6s for some reason), fuel filter, IAC, driver's side O2, and a few other minor fixes. I don't think that would cause it to drop to 10.0:1? Kinda scares me because what will prevent this from happening again?
