So I finally took the car to the track. I wasn't expecting much because I had never launched it in this configuration and need quite a bit of bugs worked out. I seem to have a problem with the converter slipping at the upper end because my MPH is pretty low, and varies 2-4 mph on different runs.
Here is the best run (which isn't superb, but it's a start):
60': 1.789
330': 5.143
660': 7.952 @ 87.042
1000': 10.402
ET: 12.49@106.46
The LT1edit program shows that the converter is supposed to lock up at around 90 mph, but I really don't recall it doing it. Of course, I'm not paying attention to that. So if it is locking, the TCC may not be holding well. The converter maker said it's not a beefy clutch and doesn't recommend locking up at WOT. My best MPH of the day was a crappy 108.5, but once I get the converter figured out, I think I can definitely improve on the ET.
[EDIT] After reviewing the Datamaster logs, I think I already found the problem. It is the TCC clutch. I see the RPMs bogging and dancing around once it hits 95 mph for the clutch. With my 1/8 mile speed, I should be around a 110-111 trap speed, so maybe I can pick up a tenth or two and a few to several MPH just from keeping the TCC from kicking on?
Oh and I was the only LT1 there, and everyone was scratching their heads on a 100% smog legal daily driver sub 12.5 sec LT1 because LT1s don't get respect out here anymore.
60': 1.789
330': 5.143
1000': 10.402
ET: 12.49@106.46
