97 TA.
with key turned on, engine no runing, the pressure is around 20 psi and quickly drop pressure, I need to turn the key 2-3 times to get enough pressure to start.
at idle, the fuel pressure is 50 psi, disconecting the vacuum line from the top of regulator, the pressure goes to 60 psi.
I got no gasoline leak in the vacuum hose.
my fuel pump is 2 years old.
tomorrow I will take off my fuel inyectors and make some pressure test, I suspect on my FPR.
I appreciate any input.
