does anyone know what the tread depth is on new M?T ET Streets? I sure would appreciate the info Thank you RAY
Tread depth on new ET streets
It doesn't say the depth on their site but if I remember correctly it was 3 or 4/32.
I have run mine for 230 runs this year and still have tread left if that is of any help.94 Z28/UltraZ Hood & Box/1 1/2 Drop/52mmTB & Bypass/160 Stat/Pulley/ Catback & pipe/Kirkey seats/5 point belts/WW Wing/Ford9"-4.11- Detroit locker-Strange axles/ZEKE'S Heads & LT4 HC/Stainless Headers & Y/1LE Panhard/BMR SFCs-STB-Relo Brackets-Tunnel Brace-Adj Tq arm- Sway bar- LCAs-PHB/ABARE RACING 4L60E/COAN 3200/Monster tach & light/DS Loop
"Tread depth" is a misnomer as it applies to ET Streets. The tread consists of two grooves cut into what would otherwise be an "ET Drag". The depth of the groove is about 1/4", as I recall.
You're not considering these for street use, I hope?Fred
stick a thin ruller in there.........
but like fred said......... street use?......yikes.
my ET Streets on ebay I would hope noone would use them on the street...... I just wanted to emphasize on the auction how much tread is left on these tires. Thanks RAY1993 Z28 A4 3.73, 2800 B&M Very Clean!!
Just measured the tread depth I have left,it is 2 to 2 1/2 /32s of an inch in the middle groove and on both sides,so yours appear to be brand new !!!!
I assume you could at least use them to drive to the track if you were close? If not, then what's the use of having grooves in them?
'95 Trans Am - A4, LE2 heads, LE1 cam, 1.6 ProMags, Comp R's, AS&M CAI, AS&M 54mm, MAC midlengths, Random Tech. cat, Borla cat back, PCMforless, Vigilante 2800, 3.73's, BMR LCAs/panhard/shock tower brace
I believe the grooves are there to run in a "street legal" class . If you seen the sidewall flex these have, you wouldnt want to drive them on the street, it feels like the rear of the car is very "unstable" for the lack of a better word. They are meant just to hook up and go. Hey, you are in Pittsburgh, I am not that far away from you, are you interested in these? I can meet someone part way. RAY1993 Z28 A4 3.73, 2800 B&M Very Clean!!
I've driven to the track on ET Streets (and Hoosier QTP DOT's).... about 7 miles each way. Not really a problem as long as it doesn't rain. Definitely no cornering capabilites. And the sticky tread has a tendancy to pick up every stone on the street and hurl it into the paint on your fenders.
I also had the front skinnies (Moroso DS2's on 15x3.5" wheels) on for the drive to the track, and they are fairly scarey. Again... do not expect much in the way of cornering. And, the Weld 15x3.5's and the Moros tires are marked "not for street use".
Now I trailer.
I was just curious about the tread. I fear running sticky tires with the 10 bolt! (And I don't have cash right now - darn mortgage!Originally posted by Ray purple93Z28
I have been running sticky[DRs for 4 years and E.T.Streets this year]with my M6 and havent really destroyed anything.
This is my 3rd clutch in 9 years and I changed the posi twice in 2200 runs!!!
Just don't go crazy,if you are A4 you have even less to worry about!!!
This sounds elementary, but I tthought I would point out the obvious. It also depends on how much power your making. You could probably run a stock or lightly modded car on slicks all the time and not break, but put some power to it, and you'll break the differential.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
