my low oil level sensor is a bit loose, but before i screw it out i feel i need a question answered from some of you who know. i assume the oil pan has a welded boss that the sensor and its copper gasket screws into correct? if i unscrew the sensor out of the oil pan there is NOT?? anything gonna drop down into the sump correct? it simply screws in and out of the pan at its threads correct?
LT1 oil level sensor
1994 formula trans am LT-1,ED WRIGHT tuned PCM, urathaned rear lca's,new factory rear springs,rear replacement shocks,functional ram air 4 inch cowl hood,hiflo cat,3 inch single into hooker hiflo muffler,2.5 out dual,air foil,underdrive pullys,edelbrock torque arm,drag bags,6T MSD,MSD coil,new built A4,2200conv.massive trans coolerTags: None
As long as the sensor is not broken, the whole thing should slide out. It is a few inches long.Rob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
thanks
yes i unscrewed it and it is about 4 inches long but all 1 piece. i replaced the seal put a small amount of sealent on threads and screwed it back in tight. thanks1994 formula trans am LT-1,ED WRIGHT tuned PCM, urathaned rear lca's,new factory rear springs,rear replacement shocks,functional ram air 4 inch cowl hood,hiflo cat,3 inch single into hooker hiflo muffler,2.5 out dual,air foil,underdrive pullys,edelbrock torque arm,drag bags,6T MSD,MSD coil,new built A4,2200conv.massive trans cooler
