Hi all. I purchased a 94 Firebird Formula several weeks ago for my son to drive. (Every 19 yoa should have an F-body). The car was strong and smooth initially, the first sign something was amiss was an odor of raw gasoline in the garage. I ran all the fuel lines and could not find the source. It had the smell of gas hitting a heat source and evaporating, not a cat smell.
This week, it began to display a bog or lack of power under medium to WOT. The car feels like we are dragging the Queen Mary. RPMs come up to about 3000 and flatten out in gear. Out of gear, it will rev as normal with a slight note of misfire. I don't have access to a Tech tool and am still looking for a shop that doesn't want $75 just to hook it up and read the codes.
Any thoughts or suggestions? I am going to run the fuel lines again today and check all vacuum lines.
FBNE
94 Formula
FBNE
94 Formula
they won't do any diagnostic work, but they will pull any trouble codes and give you all that info. They also have a free tool loaner program. You can get the loaner fuel pressure gauge and return it when you are done, free of charge.
