First, the car is running!! (sometimes it is hard to start up) So i have code P0101 stored and pending on the computer. Could that cause a no-start condition alone? I know the ECU uses readings off of the MAF and compares them to MAP, IAT and other readings (Speed-density....explain please?). if the two readings are off by more than 50%, then the code will set.....Correct?
So what is main cause for this code to be set? I cleaned out the MAF with MAF specific cleaner. That didn't solve the issue. I checked the harness for correct routing, shorts etc. and everything looked fine. Could one of the MAF elements burn out after 100,000 miles or so? it is the original part.
How does the MAF sensor work? I know what it does: (basically) tells the ECU how much air is coming into the intake.
My second issue: I assume it is not normal for the coil lead to spark near the distributor during cranking (when i tried to start my car tonight, my under-hood assistant told me the coil wire was grounding and arcing before the engine would start; it would spark for a few revs, then stop then the engine would start.) So the faulty coil wire is the more likely cause of my no-start condition.
Thank you for any light to be shed upon the subject(s)
