Well, as usual I like to recharge the A/C in my bird once every 15 years or so, whether it needs it or not.....
Over the last few years I've noticed that my A/C didn't seem to put out the same degree of cold air as it used to. And if I really think back, about it, I'm pretty sure it was short cycling too--- especially last summer.
Last year it seemed pretty marginal. But it's been no big deal to me, since up here in New England I find that I can usually count on one hand how many days I desperately need A/C--- especially with being able to take the t-tops off.
Well, tried the A/C the other day and "nada"...... Compressor doesn't kick in at all. So I figured after about 15 years it might be due for a charge!
So, a couple of questions to anyone who might know:
On a 94 Formula, LT1 A/C system, any idea around what psi the pressure sensor switch drops out?
I put a gauge on the low side schrader valve and it's showing around 20 lbs. I know that's pretty low, but does anyone know what the threshold is?
My Haynes manual, ( I don't know why I even bother looking at this thing anymore.....
), suggests that if the pressure is too low, and the pcm is not allowing the compressor to come on when you recharge, to "pull the connector from the pressure switch and short the connections to force the compressor to come on".
O.K. first of all, I can think of some reasons why this might not be such a good idea to do in the first place, but assuming for the moment it's o.k., the switch has 3 conductors. It would have been "brilliant" of ol' Haynesie to mention which two to short......
Has anyone here, tried to do this before?
I'm thinking the increase in pressure by just putting the r134 in, might make the compressor kick back on during the process anyway, but I'm wondering if anyone else has actually had that happen, or if I'm just being overly optimistic.
As usual, any and all advice is greatly appreciated!!
With the definite lack of any evidence of Global Warming up here, with temps in the 50's tommmorrow, I'm not in a big rush to fix this this week anyway. But it can change pretty quickly here.
Actually....this week is reserved for the window motor replacement.........aaaaaarrrrrrggggghhh!
), suggests that if the pressure is too low, and the pcm is not allowing the compressor to come on when you recharge, to "pull the connector from the pressure switch and short the connections to force the compressor to come on".O.K. first of all, I can think of some reasons why this might not be such a good idea to do in the first place, but assuming for the moment it's o.k., the switch has 3 conductors. It would have been "brilliant" of ol' Haynesie to mention which two to short......
