My battery was good, had it tested at Autozone, alternator was only reading 13.5 volts when i tested it on the car, and when the load was put on, with the AC on too, it dropped down to 10.5-11 volts, figured alternator must be going bad, so I replaced it int the parking lot, took 10 minutes. Tested it then, doing the same thing. It reads right above the red mark in the car, which looks to be around 11-12 volts, but on a test machine it shows 13.5volts consistently. My problem is now, it keeps dropping low enough to trigger the service engine soon light, I have checked the wiring, everything looks fine, any ideas on what it could possibly be?
Thank you for your help.
